Status
Not open for further replies.
1 - 9 of 9 Posts
Looking for the above as mine is dead second hand or new obviously not if its going to cost me an arm and a leg
I have just sent you a PM. Let me know.
So the pump proved to be your brake problem,. :crybaby2:
Yes big tears! I can source one locally for R3500.00 its a second hand unit but the plan is to use the two to make a newer one
Well, my pump went bad this year, but instead of buying a second-hand one or a brand new one, I went with the rebuild route. Cost was $250USD, and took only a day. You may have to do a bit of a search to find a motor rebuild shop that'll take on the job, but technically any automotive alternator/starter rebuild shops should be able to do it.
Another option would be to do it DIY. lrscott did a write up on this, so you may want to reference it.
Can’t get hold of a second hand unit in SA, getting desperate please if anyone can help
Put it in the Wanted ads area.
Thread locked.
1 - 9 of 9 Posts
Status
