Hello guys, I need your help with a issue with my abs brake pump. My abs pump runs constantly with no stop whenever i turn the ignition on. I changed the accumulator, pressure switch and abs relay in fuse box and the problem still exists. If the ignition is switched off there is no problem whenever i turn the ignition on the pump never stops. Its a mark II p38
