My nephew recently got a 99 bosch on coils and the ABS modulator unit was supposedly replaced with another. Based on the price it was obviously used [$550] I'm not quite sure if the issue came with the truck but likely. During some rangie testing, read sliding in a corner with gas on, the spinning wheel gets the brake applied but it does not seem to release when it should. { I believe that this is the sequence of events] In all research the closest thing I've found to promote weird behaviour would be a broken reluctor ring. If anyone recognizes symptoms from this sketchy info I would appreciate a reply. At this point he pulled fuse 24. I don't think wheel sensors have been checked. Thanks.
