Hello all,
I am new to the group. I have owned my 95 LWB for a long time. Recently replaced all my brake lines because they were looking bad! Bled everything out. Have a good pedal. However the ABS and TC light are now on. Had a code of 4-12 (right front wheel sensor) bought a new one and installed but the code still reads 4-12 when I run the test. Any ideas on what to do? I tried to clear the code by pulling the jumper wire during flash sequence but the code is still there. Might I have a bad wire from ABS module to sensor? If so, how do I test? I have had bad parts out of the box before but I have a hard time believing it this time.
Thank you
Chad
Thank you
Chad
