Yesterday I was exploring an area in Surrey with my brother...when we got stuck in a water filled sand hole! Yes, I got my 96 4.0 stuck...only because I became high centered.
Anyway, one Ford Ranger, one GMC 3/4 ton, one 1T tow truck and 2 hours later I was free! In the meantime, the water line was about 3 inches above the door and over 3/4 way up the tire. No water got in, but the wheels look like they were sandblasted (or three of them at least).
Now the ABS and TC lights stay on and ABS Fault and Traction Failure messages appear at 30kph. When I turn the RR off, the Traction Failure message appears again. I know that the ABS and TC are related to each other which might be the reason there both on.
THE MAJOR PROBLEM:
when I go faster than 30kph, I can hear the ABS clicking sound. There seems to be no pattern with the clicking sounds. When I use the brakes and slow to 30kph, the ABS kicks in for no reason. Twice while trying to make it home, I had to use the emergency brake because It felt like there was no brakes at all! 30kph seems to be the magic speed to cause this ABS issue. The RR WILL STOP, but not gracefully. Once stopped, speeding up again to 30kph the ABS clicking noise comes back and when slowing passed 30kpm, the ABS kicks in again.
Has this happened to anyone out there before?
Any ideas what the issue with the ABS could be? I would assume that the ABS sensors on the wheels would be water proof.
THE MAJOR PROBLEM:
