1 - 1 of 1 Posts
Hello all,
I am experiancing an issue with my 91 classic.
This is what happen before i changed the Accumulator .. The pump would kick on when i started up and stay on for 120 seconds then it would kick back on in 25 seconds and run for a short 2 seconds. I gathered that i should change the accumulator so i bought on and replaced my accumulator this weekend. after i installed it i wasnt sure what to do (ie bleed fluid from the accumulator or leave it.)
So i ended up turning the ignition on and opened the bleed valve and waited till the fluid flowed constaint. Then i caped it and took it for a drive.
now the pump kicks on less often than before but it stay on longer about 6 seconds.
What should I do ??​
1 - 1 of 1 Posts
