I've been having some really odd behavior coming from the front hubs. Turning either way resulting in some clunking and clanking around until both the ABS and TC lights came on. Now my break pad wear was less than 5mm on all pads so I had them changed and I still have the lights on and the occasional odd sound when turning. Is it the TC trying to grab the rotor because it is malfunctioning? Also when I brake while turning into a parking spot, the steering becomes impossible to turn and I have to stop, back up and drive in. My turning radius is gone. I looked at old posts and didn't quite find anything pertaining to this. Not sure if it's a relay issue, (pull out clean and replace) or if I have more serious ABS TC issues. It's definitely mechanical, but are the relays causing it?
As always, any help much appreciated.
Oh yeah, the LR dealer doesn't even have the ABS gear to plug it in. I'd have to drive over an hour away...
