Ooops, makes sense! THX for correction ...Other way round, 30-45 seconds is good as it is filling the accumulator, less than that and there is little or no Nitrogen left in it. More than 45 seconds means the pump is getting weak.
I'm confused. Sounds like it will just need a top off. Your rule of thumb clashes with that view however.normally after replacing accumulator, system simply requires a top off. rule of thumb whenever opening a hydraulic system it is wise to bleed pressure before and air after performing task.
