2006-2009 Range Rover Classic
Hello. In my 2009 HSE, the A/V system keeps shutting down and powering up. When I start the truck, the radio goes on as normal. Them, after 16 seconds (ALWAYS 16 seconds) it powers down and is off for 20 seconds (ALWAYS 20 seconds) before powering up again. This will keep on keeping on as long as I am in the vehicle.
The battery has not been disconnected nor has the vehicle been exposed to excessive water. This just started out of the blue on 1/2/2016.
Any suggestions?
Thank you
Sounds like your battery is getting weak. My 08 would do this with the ignition on but not running and a new battery fixed it. These trucks pull hard on the battery when the ignition is on and during starting. Interesting the engine is pretty easy to start so they will start with a weak battery but the low voltage will make the electronics go crazy.
