RIP Our Friend
A couple tiems a year I remove my roof rack and basket to give my roof a couple coats of wax. I blow the pine needles and dust out of the roof rails/gutter while I am at it. This time I decided to pour some soapy watter in each of the access holes and let it sit. With a strong stream of water I was quite surprised at the gunk and crud that came out. I am sure most was pollen and trail dust, but I still removed a few chunks of unknown bits. It took three rounds of this proceedure to get clear water. If you have never cleaned out your roof gutters it might be a good idea to help prevent corrosion.
RIP Our Friend
? HUH? Dear aint nuttin to lube on dem dar rail thingies.
Unless you lube your screws.
RIP Our Friend
Perhaps we are talking about two different things. There is no mechanism or moving parts in your rail gutters. There is a ridge that your sport bars or roof rack bolt to, but no moving parts. The roof rack utilizes little brackets/tabs and compression to hold them in place. For the roof rack there are two of these brackets/tabs behind each of the 6 finishing plates. These are held in with just allen bolts. Perhaps you have an after market system with a different mounting system?
Oops, talking about a completely different thing........I was thinking sunroof rails.....not roof rails.
