Good day to all.
A few things are happening, old and new stuff.
1. The Rover goes into Off-Road mode on it's own. I lower it to Standard and before it drops to Standard, it goes back to Off-Road.
2. I start driving after messing with this thing then I take a left turn or hit a bump in the road and the Amber Suspension light comes on... Turns to red and them "Suspension Fault - Standard Height Only'.
2a. I restart the Rig and the light goes off until another hard left turn or pothole.
3. The Indie shop here (in Bahrain) has changed out two different Rear-right height sensors and still get these codes below
a. C1A75-1C: REAR RIGHT HEIGHT SENSOR MECHANISM * Circuit voltage out of range.
b. C1A11-64: PRESSURE INCREASES WHEN SYSTEM INACTIVE* Signal plausibility failure. (I suspect this on is why the Rig goes into Off-Road height).
c. C1A06-1C: REAR RIGHT SENSOR* Circuit voltage out of range.
d. C1A06-92: REAR RIGHT SENSOR* Performance or Incorrect operation.
If anyone has any ideas or seen this before, help a Rover brother out..
- Carlos
Trace the circuits and check the connector for the sensor. Might also help to monitor the voltages while you're driving.
The Mechs said they traced the lines to the connector and found nothing. How do you monitor the voltage while driving. I don't know how to pull those specs up...
