1 - 10 of 10 Posts
When I purchased my nearly non-running RRC the PO showed me that the AC worked but he had to fiddle with the button to get the light to come on. I didn’t actually have time to verify if the air did in fact get colder.
Fast forward to now, post engine repair and I have no AC. I wasn’t surprised, but now I’m trying to figure out the cause. Here’s what I know:
1. Light on the AC button doesn’t come on and for that matter, none of the buttons on that cluster seem to work. And yes I checked the connections.
2. The main AC fuse is good
3. There is coolant in the system judging by the little view window. No idea what I’m looking for there, I just see that it’s not empty.
4. Compressor does not kick on
Is there a way to manually kick on the compressor? Not sure where to start.
1995-2002 Range Rover Classic
follow the diagram on rave. check your head pressures, the back of the connector fails and thus the switch tends to follow, there are a few relays in the system. rave is your friend.
Is this the RAVE? I downloaded it from this site, but in a lot of these discussions I can’t seem to find the info referenced.
I should clarify that in this case I was able to find the section on air conditioning, but in regard to most electrical questions the referenced sections seem to be missing. Anyway, I want to make sure I am looking at the same source being referenced.
You can jump the compressor at the relay
It should be in the passengers foot weld
Left side that’s how I got mine to take it charge
What year is yours I miss d that part
Discussion Starter · #8 ·
There is an electrical trouble soothing manual too, let me know if you need it, I can send you the file
That would be really helpful, thanks!
95 uses a nippondenso hevac system, this system uses a 4 prong relay near the blower motor, if it fails the hevac will not run. for the 95 it is best to reffer to the discovery 1 section, it has better coverage on the later hevac than the range rover section as d1 had been fitted with denso hevac a few yrs before the 95 classic..
1 - 10 of 10 Posts
