1 - 1 of 1 Posts
hello all !
here's the issue at hand:
99 range rover 4.6 hse
reverses at a snail's pace, if at all (feels and sounds more like it's in neutral)
local mechanic (not a rover shop so code # not the same) showing code 20 "gear ratio monitoring (4th gear).
also shows code 05 "lock up...clutch monitoring".
could this mean one of the following:
  • xyz switch and cable must be realigned ?
  • must replace the transmission ECU ?
the car has 105K miles on it and has always been impeccably maintained.
any suggestions ?
many thanks.
1 - 1 of 1 Posts
