I wanted y'all to know.
Last year I replace the radiator, water pump and thermostat on my 98 RR. I used all the orginal hose clamps except for one. For the last week or two I noticed the water in the overflow tank was about 8ozs low. A little less than a bottle of spring water.Every other I day was adding water. No water was dripping under the engine while it was hot and not water dripping when the engine was off.
Today I found my leak. It was leaking from the only new hose clamp I installed last year. I tightened the clamp one turn and the clamp was tight. I know I tightened when it was installed, but I guess the cold weather made a differnece. I still have the original spring clamp and I'll replace the new adjustable clamp with one that will remain tight. I had put cardboard under he engine several nights but no spots so it didn't leak every day.
It was socketed tight but not over tight when I put the new clamp on. I guess the hot and cold, hot and cold made a tiny leak. The leak started when it got below 30 degrees.
Hope it helps someone else
The problem with jubilee clips is they don’t put the same pressure equally all round, refit the spring clip or buy a new one, yes there a pain, but if you invest in the correct tool there a synch to swap out.
it sounds likely the drip is when hot so it evaporates on the heat side of things,so a good job finding it
I am not a big fan of jubilee clips. I have replaced most of mine with constant tension hose clamps. They need to be sized correctly to work but are a cinch to take on and off with the right tool.
