1 - 9 of 9 Posts
I replaced the left front brake rotor today and the rotor screw stripped out. I'll replace the right rotor tomorrow.
Where do you find rotor screw? I may need two.
The rotor screw isn't really necessary as it doesn't do much but hold the thing on to help with reassembly. So I'd say don't sweat it.
I wholeheartedly agree with DaGlitch!
I'd agree that it isn't really necessary as the wheel will hold the disc in place once it's fitted. If you really want to replace it the part number is SF108201L but it's just an M8 x 20mm countersunk head bolt.
Discussion Starter · #9 ·
I found them. A local shop called, Screw, Nut and Bolt, had the exact screw in stock. 50 cents each with no tax.
$1 for two, that's a great deal.
1 - 9 of 9 Posts
