One of the blades broke on my 95 classic. The fan from a 98 P38 fits with a little shaving of the inside of the lower shroud. P38 fan has more pitch but fewer blades. Does it draw more air? My alternative is the one piece fan/clutch from a disco II. Both are at my local U-Pull It.
Discussion Starter #2
The stock 95 fan is an 11 blade while the P38 is a 9 blade with coarser pitch. Wider blades on the P38 as well.
as you have noted it does require some custom work but yes they do fit, I'm running p38 fan viscous and 95 rr fan blades on a 95 classic.
I did not use the p38 fan because of the trim needed and I had just installed a new classic shroud.
