So, the LF window will not roll down. Functioned normally last time driving. When I press the down button nothing happens. When I press the up button I get the fault "window not set LF window not set". All other windows and sunroof function normally. How do I determine if it is the switch or the window regulator, or other?
Thank you for your time.
David
Super Moderator
Poke the switch very hard lots of times and see if it tries to move, then it is the switch. If you have a Nanocom, you can operate all the windows with that which will confirm if it is the switch or window motor. In most cases it is the switch, particularly if liquid has been dropped into it.
So, poking the switch hard had no effect.
Can someone with more ability than me to read a schematic, tell me, which wire, or wires (of the 6 at the plug) will have power to the window motor when the switch is pressed?
So, it is not the switch. Same result with one from a breaker.
Super Moderator
The wires that go to the motor are the Grey/Green and Grey/White. If I remember correctly, they are thicker than the others.
