No you don't.96rover said:I have a 96 range rover sport.
If disconnecting the steering column, be very aware that you could damage the spiral cassette (electrical connections to the steering wheel functions like horn, radio controls, etc.) if you rotate the steering wheel too far.wanjman said:it's possible that at some point the tie rod was disconnected and then reconnected without the steering wheel being at the center of its travel radius, if nothing is rubbing disconnect and re-center the steering wheel.
