Yesterday I go out & try to start her up and she wont turn over. I notice the gas light is on so I get a jug and add 1 gal of 93. Nothing. I add another gal of 93. Nothing. I add another gal of 93, still nothing but now the needle just about on 1/4 tank.
Now the battery's dead from all of the cranking.
Today I return the battery to Autozone for a new one and buy a fuel filter ans some fuel sytem cleaner. I realized that in the past few weeks, whenever I rev the engine then let off of the throttle, she will stall and sometimes cut off. So I thought, fuel filter.
Just replaced the fuel filter and she still won't turn over. I depressed the Shraeder valve on the fuel rail and some fuel came out. Then I had my wife try to start her while pressing the gas pedal and no fuel came out of the Shraeder valve. Could this mean a bad fuel pump?
How do I check to see if the fuel pump is getting current? I checked the fuses & switched out the relay in the fuse box under the hood but still nothing. Please help as I would like to try to avoid having her towed.
Thanks!
Thanks!
