starting thread as I unappropriately attached my issue to another thread. so, the quick background.
I had completely overhauled the timing chain cover area about 2.5 years ago (new timing chain, new water pump, new thermostat, new oil pressure switch, new radiator, new oil cooler and tranny fluid cooler lines, new water hoses, etc). Notice I did not say I replaced the oil pump gear as it looked in perfect condition (penny wise and many pounds foolish). this was all done as I had smelled burning oil (but not getting a low pressure oil light). turns out, after dropping the pan, I found red gasket maker clogging the oil takeup in the pan. Once all back together (not a small job), everything worked perfectly until this summer.
This summer, I started to get the oil pressure light flicker on low idle. then last week at a gas station, the stater flamed out (literally). So I had it towed to the house, put new stater in, turned over and the oil pressure light stayed on. I knew it was responding correctly as I could here the tapping at startup that usually gets muted after 2-3 seconds when the oil bath starts to flow over the top of the engine (not the best design for wear). this tapping stayed past that time and so I knew something was amiss.
fast forward to what to do and how to suss out. this is the RRC engine where the crank drives the pump in the TC cover and has cooler lines to/from radiator at the oil filter head. I thought maybe the radiator was clogged but from research on this forum, it appears the oil will travel appropriately (just not as cool) if that were to happen, so I've ruled that out. Note this radiator bypass functionality is not necessarily true for older RCC engines. (think 91 and before). The only other suspects would be (like before) a clogged oil pan takeup tube or the oil pump gear has gone south. maybe the oil gear was about to fail all along and has done so completely in concert with the starter motor (my guess it's just completely coincidental). However, I had a cracked oil gear in my disco II that was still functioning enough to push oil, so I'm stumped on what's really going on.
The betting folks herein have weighed that its the takeup that's clogged. only one way to find out. so i'll get the parts needed, start the tear in, and report back. Any thoughts on additional items or missed culprits, please advise. thanks
