1 - 1 of 1 Posts
hello gents
Sometimes when my headlights are on and when i select the high beam i get the fuse12 13 14 15 failure,i have posted earlier abt my fuse box but when the electrician checked it he said tht it's not corroded it's only where the bat cable is attached it's burned.
I checked the grounds exept the becm ground it's all ok.i have noticed that my interior light is dim when i get the fuses failed message.when i press the interior light switch the problem is solved and my rh headlight comes on again.is this problem related with a bad door latch also coz my central locking plays arround.i have a new bat and the alternator is charging 14.2 on 2000rpms.i read the posts and related prob but i want 2 repair this pro.so an acurate answer is appreciated.thanks
1 - 1 of 1 Posts
