Anybody have good or bad to say about the Atlantic British A/C& Heater motor Resistor kit? I will say it looks nice and shiny But I do not see any heat sink paste between the resistors and the mounting plate.
Waiting on an answer from y'all and AB before I remove the rivets and clean, paste and re-rivet them back on. I just hope I am a lucky one and can pull the connecting lead out to fit. As I don't want to have to lift the dash top as I might find more crap that the PO's have done to this Rangey.
It is a good upgrade... and works...
Also yes bright and shiny nice anodized finish...
And if you change it through the cowl
Vents... tiny or small hands works better... mine barely squeezed in the slot...
Removing the cowl was more work than I thought needed
Mine works great.
Didn’t remove the cowl, but used some blue tape to hold mounting hardware on driver.
The original one was toast.
