I know this must have been covered by someone at some point but I cannot find it by searching.
Looking to remove the cluster in my 94 RRC and replace all the bulbs without causing permanent damage to the binnacle cover or cluster itself.
Tips and tricks are very much welcomed and appreciated.
1995-2002 Range Rover Classic
remove the back cover, disconnect plugs. remove knee bolster, then next to steering column on both sides you will find 4, 8mm drive nuts. remove those nuts and lift cluster.
as per being careful, it goes without saying due to the vintage of the vehicle.
