went to start the old girl the other day and no start, after diagnosing came to a bad starter. being dumb forgot to label the wires. so three hard wires HOT, ground and starter relay? how do i reconnect the three to the two bolts on the solenoid? any help is much appreciated.
Sorry, I didn't read carefully enough. My previous post was about the hot wires. On mine, the ground cable is obvious because the insulation isn't complete. It goes on a starter mounting bolt (the bottom bolt is a lot easier than the top one).
If you blow off attaching this ground wire, it's possible for it to wiggle round to the hot wires. That can fry the ignition load relay (maybe best case).
