I have an 89 Range Rover Classic, that I had to change exhaust manifold gaskets on, and a bolt broke, so I had to take it off to get it it fixed. Since the truck was running fine when I took it apart, I had marked the distributor and used those marks when I put it back together. I got 6 degrees TDC number 1 cylinder, made bright white marks on the timing so I could hit it with a light, started the motor, the timing is dead on, but must feather the gas. It does not backfire. The timing is right on.
Checked to make sure everything was hooked up, the only thing missing is a vacuum line on the throttle body, I cannot find where that goes, as it was never hooked up before I had to the head.
My FIL and I have been trying everything we know to get the truck going again. We are heavy equipment operators/mechanics, so we should be able to get this going. There must be something we are missing.
The Firing Order I have is 1-8-4-3-6-5-7-2. The manual does not give a good starting point for number 1 on the cap, so they way I have taken it as is that number 1 should be before the clip on the cap, and number 8 should be after the clip headed toward the vacuum advance. I heard of a guy, using 1-2-7-3-4-5-6-8, but again, no starting point for number 1. Are there different firing orders for this 3.9l Rover?
Any ideas or suggestion, please do, there are NO Rover people around here, and the closest dealer is well over 2 hours away from us.
Thank You
James
Thank You
James
