1 - 14 of 14 Posts
Hello friends! Hoping to get a little help here. I've had a persistent problem with my 89 Rangie “misfiring” when warm. I put misfire in quotes because it’s not really a misfire but more like all cylinders shut down for a second under load.
She starts right up and idles nicely. Runs pretty well for the first 4 miles or so but when it warms up (normal operating temp) it "misfires" under load-when I hit the throttle to get up a hill. The EFI light will stay off until it hits that shut-down stumble then it comes on until I clear it by removing a battery cable from the terminal. So far I've replaced the fuel pump, coil, coolant temp sensor, added a new alternator, distributor cap and rotor and still problem remains. I'm at the end of my rope of things to try. Any suggestions? Your help is very Much appreciated!
Could be worth looking the TPS (throttle position sensor) it should competently bring mixture up under acceleration demand, if not the motor can feel like it falls flat on it's face as you ask for more torque.
Also check vacuum to distributor as it will affect this area of running.
1995-2002 Range Rover Classic
your failure is typical of a failing speed sensor aka cruise control transducer. it governs the engine by means of cutting a whole bank thus reducing power.
The Cruise control has never worked since I've owned her in the last 6 years.
No I doubt it would change with temperature, just that during cold start and warming it'll be running richer in response to input from water temperature report to ecu. That will just make it accelerate more readily but the effect of this on fuel map will diminish as temp climbs to normal.
Normal temp running will run quite lean on low torque demand, supplemented by giving richer mix in response to bigger throttle demand. It gets this from TPS, so if faulty it may not supplement sufficiently to give smooth response on demand. You may be able to increase speed by backing off demand and letting rpm climb gently, but obviously faced with a slope you can't do this.
It may be worth checking against spec to see if it's not giving you correct response to eliminate it.
What code does the check engine light produce. I see you say you cleared the codes, but never say what the codes are. the codes may give a good clue as to where to start troubleshooting.
if you read the rave section on fuel injection you will find where the transducer is needed for engine performance including idle and not necessarily for cruise control.
another great read is britishv8.org
Do you think you'd get a cross check on transducer from other functions?
Mine on a ZF 4 speed brings the torque converter lockup in at exactly 51 mph bang on every time, is this read from transducer do you think?
If thats the case, you'd at least get a confirmation it was working.
If that's the case, you'd at least get a confirmation it was working.
no, your transmission is mechanical thus transducer does not interfere with transmission operation. if you wanted to change shifting points one of your adjustments is the throttle kick down cable, more in depth changes and adjustments can be performed at the valve body. that is more of an expert situation.
Simon it's an 89 no codes just efi light.
I'd not taken that into consideration in my assessment ;) Thankyou 95classiclwb as you're entirely right, it has no electronic management. We also run a ZF5HP24 in another vehicle which is electronic control with adaptable strategy in shift pattern.
It is uncannily accurate at 51mph though. We have a route into London and our home with a 50mph speed restriction for some miles and you can just feel it dropping in and out if you're just trying to stay around there.
Question for the OP, does it take a quick full throttle blip when warmed up but stationary? Or does it give the flat spot like that too?
New here so sorry to jump in on this, but it sounds a lot like the commonly overlooked ignition amplifier that is mounted to the side of the distributer. If you are facing the engine, it will be on the right side and about the size of a pack of gum. They are prone to going out from excessive heat and I would wonder if it would act up more once the engine is warm. It is supposed to amplify the spark and will quite under load making it very hard to test by just removing a spark plug wife and they make a relocation kit on the radiator support to get them away from the heat.
1 - 14 of 14 Posts
