1 - 10 of 10 Posts
Is this possible? 90% highway driving. I'm having trouble believing this due to the fact that most seem to do a brake job at 30,000. Didn't have to replace stock tires until 52,500 if this is relevant...
Thoughts?
It's possible. Check your front pads regularly from here on. There has been an instance or two here where the sensor did not activate.
Not unusual. If you drive like I do, you're not hard on your brakes.
I drive pretty hard (no coasting... full on and hard(ish) stops) with 50/50 hwy/city.. and made it to 50k. So yeah, it's possible. Friend of mine with a SC made it less then half that...
Mine came on around 30-35k and I do mostly city driving. So it's not unreasonable that if you do 90% highway driving, the pads may last to 60k.
Goinkin said:
So what is the cost, dealer-wise, to get all 4 pads and rotors replaced?
There are 100 threads on that. Somewhere between 1000-2000.
58K is really good. Lots of highway driving will get you there, apparently...
2013-2015 Range Rover Sport
DO NOT wait until the brake light comes on!!!
I did, it never came on.
DESTROYED my rotors - caliper went bad, had to fork out LOTS of money to get that garbage fixed. Problem with e-brake shoes, etc, etc.
Frequently check
1 - 10 of 10 Posts
