My Land Rover will not go ino 4wd, when I put in 4wd all that happens is the light on the dash and the lights on the 4wd selection flashes.It worked fine last year So, I do not know what happaned. What can I check to find the problem?
Let me be more descriptive for you when I put the lever over to the right to engage the lower geared functions the light on the dash and on the drive indicator flash. Why are they doing that?
The flashing is an indication that the main computer BECM has recieved the command to switch to low gear and the flashing will last till the command is executed.
As Carl said check your change over motor and transfer gearbox ecu.
