argonaut said:Any tips on where I should start out looking for problems? Is there a common cause of this fault?
Most likely it's this.don scott said:mine was buggered up...found leaks in the small air lines....5 minutes and napa gave me the line for free...all of 6"...hope urs is that easy.
DS
kmagnuss said:argonaut said:Any tips on where I should start out looking for problems? Is there a common cause of this fault?
Cruise Control
kmagnuss said:Here's your spoonfeeding for the day: http://www.rangerovers.net/repairdetail ... ntrol.html
Learn to search better. I find it hard to believe you actually did search as this topic comes up pretty much every week on here.
Bolt17 said:The cruise control fixits on the main website are a great resource. When I bought my 99 4.0, the cruise was inop and the prior owner had a quote of $300 from the dealership to fix it. I read the fixit on here, found a cracked hose, did a 5-minute fix, and now my cruise works fine.
