Gotta love Range Rovers
Following on from my other thread, I have tonight suffered some kind of gearbox failure.
I used kickdown to overtake another car, all fine.
pulled up to the next set of traffic lights and the idle was high.
car pulled away in Drive, but seemed to stay in 1st gear.
pulled over in a layby and put the transmission into Park, the idle rose to 1500rpm
turned the engine off, waited 20 seconds tried to restart - constant cranking but wouldn't fire.
tried again a few minutes later, fired no problems.
put transmission into D, pulled away, same deal, first gear only.
tried putting the transmission into 1 and working my way through the gears manually - no joy, just stuck in 1st.
reached a steep downhill and backed off the throttle to allow the car to coast - it shifted up a gear and stayed there until I had to brake for the next roundabout, then downshifted to first and stayed there.
reverse selects and operates fine.
idle is normal when in drive, but 1500 when in N or P
Any ideas gratefully received????
