Hi, a little introduction, i am a member on another forum and the guys over there are great superb and helpful, i have come over here to well ask a few questions, i know its not the done thing but i reckon i will be on here a bit more !!!
i am new to owning a p38 this is the first one i have discovery and defenders and classic range rovers the p38 is for the wife to replace her L200, BUT since the ownership of this P38 i now realise why i have stayed clear for so long !!!
Since the day we got it its never been right from the day i bought it could hear it wasn't running right and when i got it back i plugged it in to my diag for a load of codes
too lean bank 1&2
camshaft position sensor/ circuit malfunction p0340
as well as the usual ABS now and then (not worried)
I have gone down the usual route
Cam sensor changed
Crank sensor changed
Wiring harness checked from cam and crank sensors to ECM
Wiring tested for cam earth and positive from fuse 26
i have probed the cam wire whilst it was running (blue wire to ecm at tick over) and it produces around 7 - 8 v
the fault will clear without the engine running but after you start it up its a matter of seconds before the fault will re appear and is un clearable with the engine running.
I am running out of ways forward, i have no test equipment to look at wave forms, i can't believe i am the only one to ever get this fault ? but reading the net of with i have trudged for weeks on it, and its not too common a fault
I have stopped the wife from using the car for fear of further damage as it seams to be getting worse she only used it for about 4 days and i have took it off her and now its stood around for 2 weeks i feel like a right **** head.
The previous owner knew about this fault he had changed the plugs to try and correct it ( he's not mechanically minded at all he even had to buy the spanners to chage them !
too lean bank 1&2
Cam sensor changed
