I recently installed aftermarket cats on a 2006 4.4 hse. I don’t know the previous history of the vehicle so I am a little stumped on lean codes that I can’t seem to resolve.
I replaced air filter and mass airflow sensor, fuel pump and reset engine adaptions.
I did reuse the old o2 sensors and considering purchasing a new set as I still can’t get through an emissions test. Car seems to run fine, averages 16.2mpg. Can’t find any vacuum leaks, I tried spraying starter fluid around all gaskets and hoses and didn’t change rpm or anything while engine was running.
I put injector cleaner in the gas tank drove the car a little harder and one of the codes has now changed on bank 2 from p2098 to p0430.
The company I bought the cats from
Says I will damage the cats driving with leans codes for bank 1 and bank 2.
I am hoping someone on here can tell me what is going on .
thanks
thanks
