firstly does your car have cats if yes you have a closed loop injection emission control ecu which is preset by the buy the factory and is control by the ecu and the lambda sensors.
now if you remove the cats and the lambdas and fit a tune select resister for a not cat country spec vehicle then you can adjsut the co% at the air flow meter and add the super charger but if you are doing that you will need to lower the comp of the engine ensure you have a good state of engine good comp and the valve train is in good state unfortunatly once a v8 has passed the 70,000 mile mark valve train wear will cause the engine not to perform as well as it should and the change of just the cam and followers can make it feel like a new motor
