Hi Everybody,
I just got registerd and observed this forum helping DIY 's a lot.
I need help to remove the plastic trim with the 3rd brake light. I've removed the 6 screws but unable to
remove it. Is there anyother clip or something? How d I remove it without breaking it?
best regds
There are six or so clips which hold it in place check out Rave. These things break really easy.
good Luck..
Scotty
Hi,
Rave is not much help. It says about 4 studs but dsn't show where.
regds
kapilamuni said:
Hi,
regds
IIRC, i took out all the upper tailgate internal trim when i upgraded mine
Hi
There are 4 screws and 4 clips. These fall to bits because upper tailgate is slammed too hard when closing it.
I had to have a talk with the security guard at my children school as he used to slam the tailgate very hard after the kids take out their bags every morning until all 4 screws were coming out by themselves and the whole plastic came off one day.
New clips from Landrover were not in stock so I bought Discovery clips part number DYC 10031L. These clips are much better then the original ones and the female part presses into the hole in the steel frame of the tailgate and the male parts clip into the plastic part. After this they are also easy to remove.
Tailgate with female part of the clips fitted. At the upper edge are 4 holes where the screws screw into plastic inserts. Mine are all gone and i will make some from aluminum with thread and bolt the part on.
Male part at the plastic.
Male and female clipped together. They are in the package like this.
Packaging with part number.
Hole for the screw. For me in the future for the bolts M5.
Best regards
Jos
Thanks Jos.
Got the discovery clips & job done.
as u say, we need to put a bolt there.
bt regds
kapila
