360 camera not enabled on reverse gear
113 Views 3 Replies 2 Participants Last post by  tvenu
Hello has anyone seen this , it looks like an expected behavior but weird as when I hit reverse in my 2019 RRS I can see the camera but the the 360 views are not enabled and when I put it in drive immediately the 360 button is enabled again
And when I am too close to cars when parking the parking assistance view and beeps shows up but no camera, seems weird for a car with so many cameras
No faults are shown anywhere so I am confused as is this normal behavior?
My bmw will show all views on reverse with cameras and parking assistance in the camera with green/red highlights
Same with an Audi I past owned
venu
2019 RRS Autobiography
venu
When you put the car in the reverse and the rear camera activates, press the camera icon at the bottom of the screen. What happens when you do that? In my 2019 RRS ATB, when I press the camera button it toggles between the regular rear view camera, and a view that shows the rear camera, the 360 camera, and the parking sensors.
You need to make sure you have the 360 camera enabled from the camera settings. At the main screen, press the camera button, then settings, then camera settings. Press the button next to "Default Camera View Selection" and make sure the 360 camera is enabled as an additional view when forward/reverse gears are selected. Then the camera toggle I mentioned above will work.
That worked thanks
That camera settings was not easy to find
That worked thanks
