The right of passage has come and partially gone. Engine is back in but I failed to make good enough notes or pictures on these clips. Think one is back of cylinder head lh side but can't figure the other one. Kick down cable maybe??
Get very fussy about having everything factory so this will keep me up tonight... Any help appreciated
Sent from my LG-H930DS using Tapatalk
1995-2002 Range Rover Classic
yes I think the open ended clip holds the kickdown from touching the exhaust manifold, the closed loop is on the back of right hand side cylinder hear holding efi harness from same faith.
Thanks 95 clwb, they seem to suit the areas you suggest - knowing how landy built these I would wager 'the that'll do' method went into fitting these :-o
