Are these interchangeable. They are both the 14 hole type. I have found one but need to confirm in case the head is cracked as well as the head gasket blown. Cheers.
Yes they are indeed interchangeable. If fitting to a late block you just don't use the outer row of holes.
Hope that helps.
They should work fine, the differences between the v-belt and the later serpentine models are related to the front cover and I think, the crankshaft nose.
