Thank you that a big relief. Took her into the garage today to have the gaskets changed so I am hoping and praying that it will just be them. I have found some 3.5 and 3.9 heads just in case at reasonable prices. I suppose the killer would be if it is the block itself :crybaby2:
If it is just the gaskets then I might chuck some of that irontite ceramic sealer stuff in later just in case anyway. It is only £30.
Although it is a 1994 and one of the last before the soft dash it does not have a fault display LED under the seat. Is there any other way of checking for faults?
ray:
