Anyone with some knowledge of the V6 Essex engine as found in the Capri? I'm having a problem locating the correct starter motor for a SeriesIII with the Steve Parker V6 conversion. Anyone know someone who may know... :pray:
if you still need the info PM me and I'll rummage through my Scimitar spares stock as I may have 1 +/or at least look on the parts cd to try get you the info - what's wrong with the existing unit as apart from the coil most bits are replaceable
Jon - Thanks for the note. Missed it though, but maybe I will call in the morning just at the worst possible time. :lol:
I think I've found the solution. The 3.0 is an Essex engine and I believe the starter motor is a LMS014. I can't tell what is in there at the moment but the outer case is listing a Bosch number which most likely is going to lead me to an incorrect starter.
