I have read the manual so, please, no RTFM.
My one touch window raising doesn't seem to work. Lowering works fine. I'm just checking in with other '18 owners to see if your one touch window raising works. I have to hold the switch until the window is completely closed. If there is a setting for this, I can't find it.
Thanks in advance.
I had this occur after I disconnected the battery. I believe that I had to reset the one touch feature by holding the switch in the 'up' position for a few seconds and then the one touch worked properly.
Steve
SUPER MODERATOR
Just like stemikel said you might want to try a Window Reset for Anti-trap Protection - from the manual:
1. Close the window fully.
2. Release the switch. Lift the switch to the close position and hold for 1 second.
3. Repeat the procedure on each window.
In the old days the car would beep when this wasn't set - and I mean the real old days, MY95
