So I've had plenty of cars with and without the cartridge style filter. I had a chance to change out the oil filter today and noticed I can't seem to pull it out of its housing. Is there a special trick to removing the cartridge on a TD6? Thanks!
No special trick...the cartridge snaps in place so you have to wear gloves and give it a good pull...the new one will go in and snap in place...
ASGIBM, Thanks. I used some grips and pulled and it eventually came out + some residual filter material. I would've done that earlier, but wanted to make sure it wasn't going to break any components just yanking away. First time out of many many cars that I actually had to ask a question about an oil filter.
