I was seriously considering adding the Active Key but the first quote from my local dealer was over $1000 US (including programming & tax, etc.) I called a different dealer and asked about their Active Key programming charge - and it was much more reasonable at $125. (all keys are required to be present for re-programming, btw)
That led me to eBay where I found Active Key wristbands for much cheaper, but then I also saw references to Active Key transponders.
My question: Can you just buy an Active Key and have it programmed like you would a regular remote control? Or do you have to also add a transponder to link the Active Key to the car in a different way than the regular remotes work?
TIA,
Brian
Re: 2017 RR TD6 - Adding Active Key: Cost & Required Parts?
Hi will need a whole body control module and that is the expensive bit and then there is a whole lot of programming to be do to the car and you r keys plus the wrist band thats why it costs so much.
