1 - 12 of 12 Posts
2016-2018 Range Rover Sport
So I’ve had the SVR for a about a month now (my first Rover) and two things I’ve noticed:
1. Annoying break squeal from front brakes at low speed as I come to a stop. And the brake dust is like nothing I’ve had on any car before. Is this normal?
2. In Dynamic Mode, with the exhaust baffles open, I occasionally hear a “rattle” coming from the exhaust between 1500-2000 rpm. It’s not always present though. And if I close the baffles, it goes away, or if I hit the throttle and maintain a higher rpm it goes away. Anyone else experience this?
I love this car! Or do I call it a truck? LOL. Thanks for the help!
I’ve had the annoying squeal on a 2016 v8 dynamic with Brembo brakes (same as SVR, I think) There is a bulletin on it. Fixed under warranty.
Don’t know about the rattle?
I have had the front brakes replaced for squealing twice on my 2015 SVR. First time was around 5k kilometres and second around 30k . It was under warranty with no hesitation by the dealer as there is a technical bulletin on the issue.
2016 RR Sport SC Dynamic
Brake dust and squeal are par for the course for OEM Range Rover pads. I had my dealer change the pads multiple times under warranty and finally said forget it and went ceramic aftermarket. So much better now.
Thanks. Whose ceramic pads did you go with?
I hear good things about Disc Italia.
I’m going to order this set. “ Disc Italia hyper performance”
http://www.brakeworld.com/brakedetails/2016/land-rover/range-rover-sport/disc-italia-hyper-ceramic
When I had my 16, the TSB they finally came out with worked. It was a front rotor and pad complete replacement (had to be the new set with the new compound on fresh rotors) and it was perfect after that.
RIP Our Friend
There were a total of three pad styles with different components. Original, then two TSB with a different component change for each. Yes OEM pads create more dust than some after market pads. That's due the pads being slightly softer to allow for shorter braking distances in emergency situations while maintaining smooth stopping in daily driving.
I have those Disc Italias from Brakeworld. The amount of dust is night and day. I have not noticed a difference in performance.
Hodog has heard me say this before, but the DI pads are outstanding. No dust and no squeal.
Yup, stemikel and I should be getting commission by this point. :mrgreen:
Discussion Starter · #12 ·
Thanks for the feedback guys.
1 - 12 of 12 Posts
