Hello all,
I have a 2015 Range Rover Sport Autobiography with climate front seats. Love the car, but find the having to use the touch screen to control the climate seats a bit of a faff! Sounds like a first world problem I know :rolleyes:, but having to wait for the system to boot up when starting etc often means I'm half way down my road before I can even select the seat heating controls.
Now obviously Range Rover thought his too, and added the seat control function to the temp controls in the centre dash.
My question is, does anyone know if it's possible to retrofit these controls? The module is the same but I'm unsure on the wiring or and if the system would need recoding to accept the button push as a command?
2016-2018 Range Rover Sport
mine work by pushing the temp display and rotating the dial to the left.
Hi DieselD, what you’re describing only works this way from my2016 cars on. This is what I want, and the reason for my initial question.
2013-2015 Range Rover Sport
From the 405 forum but the module should be the same between the sport and full size.
L405 HVAC Control Upgrade
2015.5 RRS HSE SCV6 USA
