21 - 28 of 28 Posts
i took the vehicle to landrover they are telling me no communicaton with acm moduleand it is $3836 they are telling me it has a good power good ground it needs a new audio control module let me know if anybody can help?
hey rrs15drvr where did you find bad fuse where is located can you tell me ?
Rear fuse panel is on the right side of the trunk, you have to pop the panel out by pulling below the hooks. There you will see in the top left 3 40amp fuse links next to each other. That is what powers the audio system
2016-2018 Range Rover Sport
The main audio control module is in the dash and also houses the CD player. You can buy used ones for much less than $1k on ebay but they need to be reprogrammed to your vehicle. I doubt a dealer would do that for you on a used unit. That is the main brains of the system. The amp is just an amp.
21 - 28 of 28 Posts
