The amp is definitely under the left hand side front seat. I say left hand side because I am in the the US and I don't want to confuse "driver's side". Regardless, you can't see it just looking. You have to remove the seat. the amp is under the carpet. The floor carpet overlaps under the seat and when you peel it back you will see it.Thanks Scott, you're a big help. Before I left the dealer, he told me it was located in the cargo area (passenger side). I pulled the the side carpet back and didn't see it. Read your post and looked under the driver's seat (from the front and rear) and didn't see it there, either. I only saw the seat motor. I'm assuming once I take the driver seat out, it will be visible.
No navigation, radio, phone, or bluetooth capability one morning.
I thought this may have been a blown fuse but the dealer is recommending a new $2900 audio amplifier to correct the problem.
Anyone else ever have the same issue?
CC
Looks like I’ll take your advice and buy a Most optic bypass loop. The dealer diagnosed the problem as a bad amp, however the replacement amp did not solve the problem. I’ll return the replacement and start the search over by isolating each component.The amp is definitely under the left hand side front seat. I say left hand side because I am in the the US and I don't want to confuse "driver's side". Regardless, you can't see it just looking. You have to remove the seat. the amp is under the carpet. The floor carpet overlaps under the seat and when you peel it back you will see it.
I’m back home and have the bypass loop now.Throwing parts at the problem is expensive, even when they are used parts. Bette than $2900 and hopefully you can return it or resale. The first thing to do with the MOST bypass loop is connect at the sirius/Dab unit near the spare tire.
Hopefully you get lucky as that is a $100, 10 minute fix. Other than that you have to dig into the dash to test the other items.
A little hassle to save $2500! Absolutely! Glad its fixed and you have your tunes back!Okay, it’s fixed. The diagnosis said the audio amp caused the fuse link to blow. They recommended a new amp and a replacement fuse link ($2800 all in). So, I bought a used amp for $349 and an $8 fuse link.
I replaced the audio amplifier but not the 40 amp fuse link because none of the three fuses were blown (visual and multimeter checked). Still didn’t work. So, I took it to the dealer and they said they replaced the fuse link (free of charge). Now it’s working. Hmm, I checked those fuses 3 times and none of them were blown.
Long way to the finish line but I’m out $349 instead of $2800.
