Can some one check if the passenger side window come down fully when you hold the window-down button on your driver side..
asking because, mines doesn't come down all the way if I hold the button. Driver side does.. Not sure this is the default behavior or I'm confused.. Want to get oit checked as I'm running out of warranty next month and wondering if i started having any electric issues.. Before i take it to the dealer..
Both front windows open all the way. You most likely have something binding up the regulator. You can check this yourself by removing the door panel and vapour barrier and checking to see if the regulator has come loose at one fitting or if something is caught in one if the slides.
