I currently have some clunking noise going on my 2014 SC with 135k miles. I recently had both two new front lower control arms installed and the clunking from bad bushings went away. However, now I have a new intermittent noise which is a grinding noise (like something spinning/turning) when I turn right at slow speeds. It never does it at all on left turns. I took it to the dealer and they thought it might be the transfer case, so they just changed the oil in the transfer case. That did not fix the problem and I'm left scratching my head. Suspension seems to work fine because i thought maybe the front tires were rubbing the fender well. I raised it to off-road mode and it grinds again.
Anybody had this issue before? Thanks
