1 - 1 of 1 Posts
I picked up a cheap set of 20" OEM wheels, and swapped out the original 21" wheel/tire combination on my 2014 Autobiography for the 20" wheels and slightly larger tires. As reported in other threads, the P275/55R-20 size works fine, no rubbing. I bought Goodyear Eagle Sport All-Season tires (V-speed rated, XL-load rated) from TireRack. My independent LR service place was able to reprogram the computer with the new size so that the speedo, etc. are accurate.
I took them on a test run from DC to Assateague Island, and out on the beach. No problems at all. They ride great, and give a little bit of extra sidewall and ride height for additional clearance and wheel protection.
I even helped out a stuck Ford Escape (what were they thinking) using the Maxsa Escape Buddies I bought. Worked like a champ... two minutes and they were on their way. https://www.amazon.com/Escaper-Traction-Off-Road-Extraction-20333/dp/B00AV2HONS
1 - 1 of 1 Posts
