You just need to pin point a source on which strut is losing air, then use a spray bottle with soapy water on areas, where it is susceptible to air leakage. Usually spray over the air line connector at the top of a strut and use an extendable mirror and a flash light to see, if it shows any foamy bubbles, which indicates air leakage source. If none of the air line is showing any bubbles on all struts, or if you have either both front struts only, or rear struts only sagging down simultaneously, then it could be the valve block that could be the culprit. You need to spray soapy water to see, if it bubbles up on the valve block for signs of air leakage.
I once solved my air leakage on a front strut with an air line leaking below the connector. There's no fault codes, compressor works fine, but only slowly leaking overnight. I bought a new connector part with a new O-ring seal from LR to replace it, but it did not solve the leakage problem, so I wasted $30 on a new LR part. I used a Masters Orange Tape wrapped around the brass connector thread to try seal the leak. It really worked in sealing the air leakage through a threading, as a cheaper solution fix that only cost me $4, plus $1 for a 12mm crowfoot wrench that attaches to a torque wrench to work on extremely tight limited space above the strut, instead of spending thousands on a new strut + labor installation. I no longer have any air leakage issues so far and am very happy with my DIY fix results.
Links to parts:
Masters Orange Tape
12mm 3/8 Crowfoot Wrench
